I have a Samsung Galaxy model SPH-L710. Yesterday, my phone stopped connecting to my computer. Usually when I connect it via USB the MTP initialization starts. Now MTP won
USB cables have been known to just go bad. I've seen a number of similar complaints where that was the cause. No guarantees, but you might check that out.
If it's good with your other phones, the cable must be ok.
Can you pull down your notification bar while plugged in and change from charge only to a media mode? That varies by model, so I can't describe that precisely.
Thanks. I think I am going to reinstall JB4.1.1. I think a complete restore should fix it or just find another way to transfer data. I am still open to other suggestions/fixes.
