The MTP connection appears to work on my laptop, but on my desktop (with the exact same drivers manually installed), the device doesn't work. It shows up in Windows and I can open it to see the folders in the phone and the SD card, but the files become unresponsive quickly. Example:
I'm pretty sure I have the drivers set up correctly since it's working on my laptop, which has the same version of Windows. But my desktop can't work with the MTP connection. If I try to sync the phone with media software, it hangs up and is "scanning" forever.
I've tried different USB cables and ports, front and back.
I've scoured the web with no luck. A few similar problems are mentioned, but no solutions. I'm guessing the issue is somehow with my desktop. What should I be looking for?
Galaxy S3 T999
Android 4.1.1
Windows 7 Professional
- Plug in the phone
- Navigate in explorer to my music directory and open it.
- Half of the folders load and then it hangs up. The directory bar at the top does the loading animation very slowly. The rest of the contents never load and no file operations can be done. Trying to view My Computer or looking at the portable device properties also hangs up.
- When I unplug the phone, the contents I was trying to load seem to appear for a split second before the windows close.
Galaxy S3 T999
Android 4.1.1
