Apps Multi fieldlistView or equivalent
I am new to android development and have been tasked with developing an app. One of the screens will require there to be a list of people with some thumbnail information about them, similar to:
Code:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="fill_parent"
    android:layout_height="?android:attr/listPreferredItemHeight"
    android:padding="6dip">
    <ImageView
        android:id="@+id/icon"
        android:layout_width="wrap_content"
        android:layout_height="fill_parent"
        android:layout_marginRight="6dip"
        android:src="@drawable/icon" />
    <LinearLayout
        android:orientation="vertical"
        android:layout_width="0dip"
        android:layout_weight="1"
        android:layout_height="fill_parent">
        <TextView
            android:layout_height="0dip"
            android:gravity="center_vertical"
            android:text="Fist, Last" />
        <TextView
            android:singleLine="true"
            android:ellipsize="marquee"
            android:text="Description" />
    </LinearLayout>
</LinearLayout>
This information will be stored in an SQLite DB. Now I can see that listView seems only to work with a single column. What is the best way to go about this?
Maybe you're looking for the "RelativeLayout"
Here is some tutorial and how it looks:
1.Learn Android : Android Layout Tutorial
2.Relative Layout | Android Developers
Thank you for taking the time to replay. A relative layout may be preferable to a linear one. However it still doesnt solve the problem I'm having.
How do I use this layout and repeat it for as many times as there are records in a table. Populating the various textViews with the different columns of the table?
