I bet you were at the store I was at. North Buffalo? If so, yea the docks went quick, and they didn't have any mobile docks at all. I had the rep order the MM dock and the car dock online when I bought the phone, should be here Mon/Tue.
Ironically, I have a custom iPhone mount I used for my iPhone in my car at the moment. It works great and holds the phone perfectly. Sure it doesn't allows the keyboard to slide open (why would I want that?) and it doesn't go into the "car" mode once I put it in (easy enough, just hit the Car Home app). So depending on what feature it offers (if any) from my current dock, I may return it. The custom dock I have is also not windshield mounted and is closer to me and easier to read.
If you're curious, its the APIP-VSM found here:
</title><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en"> <html> <head> <meta http-equiv="Content-Type" content="text/html
*and*
Pro.Fit Holders
Once they make a VSM mount for the DROID, I'll be all over it. They are great car mounts.
-Z
