Multiple Launcher Failures
vacren
I've read through the fixes on TW Launcher fails, they all say to either factory reset (becoming a real option real fast) or to install a new launcher.
I installed Go, which immediately failed.
I installed ADW, which immediately failed.
I installed 7, which immediately failed.
I can install from online but I can't manipulate the phone at all other than to select the launcher after installation, so I'm unable to get to app settings to fully disable TW (which I suspect is the root cause).
Now I'm looking at backup options, but since my phone is a very pretty paperweight, I need one that will allow me to manipulate it from my computer or an online server.
Thoughts?
