J
JudoKilli
Guest
Hi all
I'm not quite sure what to call this problem, or even how to identify it properly.
Thanks in advance for the forthcoming help!
1. Manufacturer - Samsung
2. Model - S6 Edge +
3. Software version - 6.0.1
4. Specifics of the problem -
5. Specify if the phone is rooted. If you don't know then it probably isn't - No
- 'switch window' soft key not working (back soft key is fine)
- menu swipe down from top works, but the extend menu (further swipe down) doesn't
- Settings and expand buttons on the swipe from top menu don't work
- Notifications buzz, ping, etc but no notifications show on the top bar (they do show on home screen).
- Installing an on-screen button app does not solve the problem - the switch window button still not work
- I have tried hard reset, soft reset, everything but factory reset.
- Everything else works fine
