Multitasking button problem
Gonzo117
Sometimes when I press the multi-tasking button, I feel the vibration but it doesn't actually bring up the recently used apps. I press it again and it works the 2nd time.
I turned off the option to bring up the menu if you hold the multi-tasking button down thinking that could be the problem, but it still happens with it off. I'd say it happens 1 out of every 10 times I push it.
Has anyone else had that problem?
Welcome to Android Forums.
I haven't encounter this with the "recent apps" button either.
Have you tried running in Safe Mode (disabling all apps you added without uninstalling them)? If the problem stops it is caused by an app that you added.
... Thom
