Also I just called HTC and they said this is a known bug and they are working on a fix...so there goes your theory that they developed it this way on purpose to preserve battery life.
Sorry if i confuss you trying to get this new tablet figured out what I was trying to say was in order for the phoje to maximize the battery life. The apps do not continually refresh in the background. This inturns means that when you re-launch an app via the multitasking option .It will then be prompted to refresh an updated that particular page.
I've installed update 1.29.401.11 and it looks like the problem is solved.
I will give it few more days in order to be sure as problem was not constant.
