Root Music/audio help
Erik-_-Chavez
Is it possible to change the system music player in sense ROMs to PlayerPro so that the tweak to change the song with the volume buttons when screen is off to work (I've already moved it to system app and it still won't work). And I am using Mobster ROM V4 and the DSP manager does not make a difference can someone help with that.
I did a quick google search and I round that it's something that a ROM and/or kernel has to enable...
I am currently using MidnightRom Senseless with the MAC Kernel, and I downloaded the PlayerPro trial and played some music and I was able to change the volume with the screen off. With that being said, you probably just need to flash a different rom and/or kernel.
