Music Player Help
RayArt
Hi,
Can anyone please help? When using the music player to listen to an album, then you want to change to another album then decide to go back to the original album it always goes back to the beginning. Is there a way to go back to the first album and continue listening from where you stopped? Does that make sense? It's particularly frustrating when listening to a audio book, then changing to listen to some music, when you go back to the book it starts from the beginning. Is it possible to go back to where you stopped listening to the book? I hope I've explained that ok. Many thanks, Ray
I don't know of a music app that does that. What I can suggest is that you use a second music player. Use one for your audio book and one for your music.
