Music Player questions
mikeb33
Member
I have the Note 10.1 and using the stock music player. I out about 1,600 songs on the SD card(basically dragged the entire "my music" folder from my PC. I created a "favorites" folder and put about 150 songs in it. I can't figure how to just play these songs. I click on favorites and a list of those songs comes up, I click the play arrow and it seems to choose from my entire library. Not just from my favorites. Does it have this capability?
I downloaded the Amazon MP3 player and it seems to have the same problem. I can make a playlist, but not just play only those songs?
Am I doing it wrong or is there a player I should download?
I am making this list for a camping trip and thre will not be Wifi, so I need a player that isn't disabled with no wifi avaiable.
I think you need to add them in the play list through the music player.
I'm stupid. When I just pressed the play arrow, it played anything. If I selected one from the playlist and pressed play, it seems to only play from the list. So, problem solved.
