hiV4A stands for Viper4Android. And IRS means Impulse Response Sample: a file used in V4A for different audio effects.
why isn't avaible on google play?
it's a great application
thanks
Actually, there's an unofficial version on Play Store. But your best bet would be to go to XDA for better support. Your phone also has to be rooted with BusyBox installed, or V4A won't work.hi
thanks
No, PowerAmp is paid software. There is a trial app you can use for a few days, but after that you must pay.hi
about poweramp is it free too ads?
because i tried to install on a phone ,but after few days ,it doesn't want to play any tracks
thanks
I use JetAudio as I use flac files as opposed to mp3.
AIMP or AIMP3? Just to be completely clear, because these are separate apps.I've tried Neutron, PowerAMP and JetAudio. AIMP3 is definitely superior to all of them in terms of sound quality. And by much.
So whoever is looking for sound quality should choose AIMP.
so I will merely ask the audiophiles among us which music player has the highest quality audio?
Which one do you think is prettiest? They all use the same codecs.
Thanks in advance for lending me your ear!
Yeah, its the parametric eq I could never get to grips with. I can remember spending hours tweaking it, and still wasn't that happy. Went back to PA, disabled direct control, installed V4A and a good IRS - job done.
Only now have found some updated V4A recovery flashable zips on xda, that include some Sony mods plus a V4A Atmos hybrid that I'm going to have to try now lol.
