Music playlists from hell. Please help me!
sunflight
I like to make playlists with the songs in a specific order so they tell a story. The default Music app on my Droid Pro was great for that purpose until its last upgrade (awhile ago, but I don't recall the date). Now, when I try to move a song up or down, the app puts it in a random position in my list! :confused: I have tried to rearrange the songs in different ways, but nothing works. Is there a way to fix this problem? I'd rather not have to download another app. I would very much appreciate someone's help with this.
I know you were using the default app, but which one? The old one, or the new Google Music one? If it's the latter you can go to music.google.com and use drag-and-drop on your playlist from there.
Thanks, Ryan. I'm using the old app, but I found a work-around that might be helpful for others who are having this same problem. If I go into my device playlists on my Amazon music/cloud player app, I can access the playlists I have on the default Music app, change the song order, and it shows up in that order in the Music app! Who knew?! :cool:
