Must constantly tap Power Button to get streaming audio restarted
  • Thread starter Thread starter Angelo Bione
  • Start date Start date
A
Angelo Bione
Guest
When I go for my daily walk, I like to listen to CNBC on Sirius XM. Basically using LTE cellular for reception. On average every 15 seconds the audio will stop. Sometimes it will restart quickly. But it will always restart immediately if I tap the power button. Other point to note that in my location I might be doing a lot of cellular tower switching.
i notice this on a few channels using sirrius on my note 10+ it will cut in and out or lose reception. if you look when the audio stops there is message some time saying checking connection. or i will see the wheel spinning as it tries to buffer the audio. i have not found a solution for it. other channels work fine. sometimes i find that if i switch channels and then go back to the one i was listening to it will reconnect. i noticed i get this issue when i have bad reception on my phone. i just kind of learned to live with it. you might want to contact sirrius and see what they say.
so yeah this is a sirrius xm app problem and not your phone.
