Have you tried the android marketplace?
Yes thats what I'm using.
I have to say I have had my transformer for a few weeks (great tablet)Well I got my transformer today and I must say the market place is looking very bare, I read all of the hoopla on lack of applications but WOW it really is bad! Anyone have any suggestions i.e. does the Amazon market place support Honeycomb? Any other options?
make sure you go to the 'root' at the top left, not just apps that were made specifically for the tablet (ie the whole Android marketplace). most apps will work fine for me that worked on my cellphone that ran Android 2.3 Gingerbread. only a handful didn't work properly/not at all on the Transformer. So in other words, there is a TONNE of apps out there that you can install!
it could also have something to do with your location, maybe, if you're still not showing a lot of apps?
Its not that there are no apps its the fact that when you install an app
that was made for a phone it works on the tablet with the a phone size
format
i
Looking for games? Go to your Google toolbar and enter "THD apk". Every hit will be a game that is optimized for Tegra 2. Download your favorites to your desktop.
Trouble sideloading? Download the TF drivers from ASUS and install on your desktop. Then download and install Android Injector on your desktop. Plug your TF into your desktop, verify that the injector finds it, and start injecting your apk files. No root required!
Looking for apps other than games? Start in the Android Market's featured tablet section and expand it. Everything there should work well on your TF. Also, maybe 50% of the phone apps elsewhere in the Android Market will fill your screen, look decent, and run properly. You find out by trial and error. Simply uninstall the losers.
