Hi everyone, I just bought this MXQ Pro S905. The problem is the remote. It work fine when I first plug the power supply in. It turn off and back on and does work fine. The issue is when I press the power to turn it off. After
10 minute or so, I can't turn the box on. Only way is to unplug the power cord and plug it back in. It will work again with no problem. But every time I turn it off and the box will have a red light, 10 minutes later the remote will not power it
on. So I purchased another remote thinking its the problem, but the second one does the same thing. I try both turning on and off the remote in setting with no luck. Anyone had this problem?
