Hi!, i just got mine about a week ago. Overall i think it works pretty good (for the money of course)
About updates, just make shure it has Android 4.0.3 installed. some had 4.0.1
If that is your case, you can find the "latest" 4.0.3 rom image on the ainol site.
For me, the things i have to complain about so far are...
- There are some chineese applications in it, i used a script to remove them.
- The tablet DOES have android market preinstalled, and it auto upgrades itself to google play store, it works fine,
however, a
LOT of applications are said to "not be compatible with my device". For example google maps, facebook, google earth, etc. I had to "manually" search for them in google and install the .APKs manually.
Ibe heard that there is a way to alter some configuration files on the tablet, to "trick" google play store (market) into letting me install those apps directly from the market, but havent found out exactly how that works yet. If anyone knows wich configuration files i need to edit, please let me know, i can use ADB).
- The "Encrypt tablet" option doesnt seem to work. It does nothing.
Other that those issues, the tablet works pretty well, and its fast.
If you need any help, links to scripts, how to root it, etc. feel free to PM me.
