Help My android is haunted.
  • Start date Start date
A
Android Question
Guest
Last night in the middle of the night (approx 4am) my phone randomly turned on Pandora, flashlight, and did a google search of a search I had made previously (when is the fall equinox), all at the exact same time. I closed all of them and Pandora turned itself on again after a few minutes. After I closed it it didn't happen again. Any idea what's going on? Thanks in advance.
No the equinox bit was something I googled a few days ago, that repeated at 4am while I was sleeping last night. It is really strange!
Not a clue actually but doing a Factory reset can't hurt. Then reinstall apps until you find the culprit. I would bet if I was a gambling man that a recently installed app may be the problem.
Try going into your Settings >> Storage >> Cached data and clear the app caches. Hopefully that will clean up things (although I guess we won't hear back from you until tomorrow after 4 am).
Note that if you do have to resort to a Factory Reset that it involves wiping all your stored, personal files so a backup is a must-do beforehand.
