My Application is not working
Code:
package com.example.masood.dogtest;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.ParseException;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.util.EntityUtils;
import android.app.ProgressDialog;
import android.os.AsyncTask;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.support.v7.widget.LinearLayoutManager;
import android.support.v7.widget.RecyclerView;
import android.view.ViewGroup;
import android.widget.Toast;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import java.io.IOException;
public class MainActivity extends AppCompatActivity {
    RecyclerView recyclerView;
    JSONObject object;
    Adapter adapter;
    [USER=1021285]@override[/USER]
        setContentView(R.layout.activity_main);
        recyclerView= (RecyclerView) findViewById(R.id.programminglist);
        recyclerView.setLayoutManager(new LinearLayoutManager(this));
        new JSONAsyncTask().execute("https://dog.ceo/api/breeds/list");
        recyclerView.setAdapter(new RecyclerView.Adapter() {
            public RecyclerView.ViewHolder onCreateViewHolder(ViewGroup parent, int viewType) {
                return null;
            public void onBindViewHolder(RecyclerView.ViewHolder holder, int position) {
            public int getItemCount() {
                return 0;
    class JSONAsyncTask extends AsyncTask<String, Void, Boolean> {
        ProgressDialog dialog;
        protected void onPreExecute() {
            super.onPreExecute();
            dialog = new ProgressDialog(MainActivity.this);
            dialog.setMessage("Loading, please wait");
            dialog.setTitle("Connecting server");
            dialog.show();
            dialog.setCancelable(false);
        protected Boolean doInBackground(String... urls) {
            try {
                HttpGet httppost = new HttpGet(urls[0]);
                HttpClient httpclient = new DefaultHttpClient();
                HttpResponse response = httpclient.execute(httppost);
                // StatusLine stat = response.getStatusLine();
                int status = response.getStatusLine().getStatusCode();
                if (status == 200) {
                    HttpEntity entity = response.getEntity();
                    String data = EntityUtils.toString(entity);
                    JSONObject jsono = new JSONObject(data);
                    JSONArray jarray = jsono.getJSONArray("message");
                    for (int i = 0; i < jarray.length(); i++) {
                         object = jarray.getJSONObject(i);
                    return true;
            } catch (ParseException e1) {
                e1.printStackTrace();
            } catch (IOException e) {
                e.printStackTrace();
            } catch (JSONException e) {
            return false;
        protected void onPostExecute(Boolean result) {
            dialog.cancel();
            adapter.notifyDataSetChanged();
            if(result == false)
                Toast.makeText(getApplicationContext(), "Unable to fetch data from server", Toast.LENGTH_LONG).show();
Manifest
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.example.masood.dogtest">
    <uses-permission android:name="android.permission.INTERNET" />
    <application
        android:allowBackup="true"
        android:icon="[USER=22138]@Mipmap[/USER]/ic_launcher"
        android:label="[USER=696546]@String[/USER]/app_name"
        android:roundIcon="[USER=22138]@Mipmap[/USER]/ic_launcher_round"
        android:supportsRtl="true"
        android:theme="[USER=19691]@Style[/USER]/AppTheme">
        <activity android:name=".MainActivity">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
Moved to Application Development forum.
Can you please explain what's not working with this code?
Why would you want to have a RecyclerView with an adapter attached with 0 items that creates null ViewHolders? Doesn't make much sense.
I guess you're pretty new to Android, but if you're serious about learning it use a third party tool for your network requests, it will save you a lot of headaches in the long run. Retrofit is never wrong but there are others as well.
