My Battery Life Settings for the Galaxy Nexus
exzacklyright
http://exzacklyright.blogspot.com/2012/06/samsung-galaxy-nexus-battery-life.html
Mainly a compilation blog. It's mainly for personal reference but just sharing for anyone interested. I'll keep it updated with anything i find.
Used a lot of info here: http://rootzwiki.com/topic/26383-my-vzw-gnex-settings-for-battery-life-thread/
and http://rootzwiki.com/topic/26334-configure-liquid-smooth-for-battery-life-secondly-performance/
If anyone has anything to add let me know and I'll update it.
I'll mainly reply to my blog or this post: http://rootzwiki.com/topic/27869-my-battery-life-settings-for-the-galaxy-nexus/
I see you have liquid as the rom. Do you have an opinion on it vs. Bamf, as far as battery life goes?
I ask because so far bamf gives me the best battery life but I haven't tried liquid.
I noticed you didn't mention anything about the color multipliers. Does adjusting those help battery life?
Adjusting the multipliers does help, or so i'm told. Some ROM's have an option is the settings/tweaks to change it, others don't and I think you have to work some ADB magic to do it.
I'm doing the lean tweaks and adjusted the auto brightness things. Its a little too dim outside. my color multipliers are all set to .2671*
To be honest I haven't extensively tested various roms / kernels. To be honest I think it's minimal the differences. There just REALLY isn't a good way to test it. I've tried AOKP and well it just didn't feel right.
I don't think so. I've never even adjusted my color multipliers ever so I wouldn't know.
Do you notice a difference though between 200 and 250? I hardly notice anything so I just kept it at 200. 250 is the max you can go.
That look about right?
