M
Member 128172
Guest
Here's the short version:
Used stock phone since release day.
The past 3 weeks or so the phone reboots itself randomly.
It kept getting worse, rebooting even more often until finally it rebooted probably 8 times a day minimum.
I got fed up and decided to do a factory reset, which I did.
The phone worked ok for a bit, but I got the idea to root it and install a new ROM.
I successfully rooted the phone.
I had trouble getting Odin to detect my phone to install 1.6. I never did flash it and did another factory reset to remove the rooting. I have to use the phone for work at the moment and just needed it to function.
Ever since I did this, the phone has been ludicsristly slow, taking up to 5 minutes to respond to anything, sometimes does not wake up, or reboots itself over and over for hours.
I have tried the factory reset a few more times, same problem. It's insanely slow and unresponsive, totally unusable.
On a side note, before any of this happened I could boot the phone and use a task killer to kill all the things that start on boot and be left with about 150mb of free memory.
After the factory reset, it's more like 60mb after all tasks are killed. From 60mb it slowly decreases as it stays on to about 28mb, or the task killer that tells me this ceases to work or the phone locks up or reboots.
I'm so fed up at the moment and I just want the phone to WORK. I don't care what OS is on it anymore, I was hoping to get it back to normal and then go from there but it's totally unusable!
I'm so fustrated I want to run over the phone with my car or throw it off a building. I can't afford to "just get a new phone" so please don't tell me that...
I was hoping to get it back to stock and then just wait for 1.6 or 2.1 to officially come down to it, but it seems I may die of old age before that happens. So not really a good option after all
Not to mention the phone is totally useless at the moment.
PS: I found out that the reason I couldnt get the "Download Mode" screen to show up and get Odin to see the phone was because I was holding down the Send button and not the OK button during bootup. But I still have NOT actually flashed the phone! It's still stock!
Not to mention the phone is totally useless at the moment.PS: I found out that the reason I couldnt get the "Download Mode" screen to show up and get Odin to see the phone was because I was holding down the Send button and not the OK button during bootup. But I still have NOT actually flashed the phone! It's still stock!
