mariibabii
Phone Facts:
Droid 2
Rooted using Z Root in January
Sent as a Verizon Replacement December 15th 2010 (Went through 3 Motorola Devours...)
Today, as I was trying to send a text, the Swype started acting crazy and started inputting random letters. Then I stopped touching my phone and the phone started resending old texts, swiping home pages, opened and closed apps and started to want to delete my Dialer. (This is when I paniked big time) It was like someone had remote access (which I bet this is what it is) to the phone, because I was fighting them just to reset the phone. I reset it 3 times tonight and even when the phone was factory clean and on airplane mode, the phone started opening settings and random apps. I just got frustrated and took the battery out and so it's dead now. I took the sd card out and it still acted like this. I even didn't sign in my Google Accounts after reactivating the phone and it still acted crazy. I'm at my wit's end and I don't know what to do!
Additional Symptoms
Droid 2
Additional Symptoms
- I had the phone off for an hour, battery and SD out. When I turned it back on and put the SD in, The date was December 31st 1969. at 7:00PM (actual time was 6:24pm)
- Phone makes calls, just trying to get to the Contacts is an impossible challenge.
- Phone was fine after the 3rd reset for 3 hours then started acting up.
