Help My Droid won't recognize my SD card
I dropped my droid today and the back came off, battery fell out etc. When I put everything back together and powered my phone back on it determined that my SD card is 'blank' and cannot be read. It asked if I wanted to format it but I declined. I have too many valuable files that I cannot delete.
I have no other phone to see if the the memory card is warped. Is there a way to make it recognize it? I've never owned a droid or really any smart phone until now. It's not brand new and doesn't have a warranty.
Advice? Tips? Suggestions? Please :)
try some rubbing alcohol in the sd slot its okay techs use it on circuit boards to clean them. make sure its in the slot properly could have damaged the card you should be able to tell that almost by looking at it.
