My flytouch power jack is loose.
it needs to be opened and soldered on more tight as its not taking a charge without me holding it in position , would anyone be interested in repairing it for me? I would pay for your time, thanks. Its a superpad 6.
I just did it on mine. It is fairly easy. There is a small dab of sollder on the back side of the jack. If you can get your hands on a fine soldering iron, just carefully touch it on the solder and drag it up on the tab. You may need to add a very small dab of solder to it.
