My friend wiped her s7 how can I fix it
I've got TWRP installed finally use Odin to upload files start flash it finishes reboots and seems to be working but wont go past first Samsung screen
welcome to AF!!!!!!
what rom are you trying to flash? do you have a link for it?
exactly what happened before this issue? the more details the better we can help you.
What is the model I.D. of her S7? Are you sure you're using the appropriate ROM for her model? It sounds like it's the incorrect ROM.
ROMs are very model specific, they are not interchangeable. Every phone model has a different, internal hardware configuration and ROMs are made to match up up with that specific hardware. If you didn't flash the correct ROM, there's a software <> hardware mismatch. In some cases the device will still boot up with an incorrect ROM, but it will be running in an unstable state and/or some features just won't work (no or wrong supporting software/driver), Or it might be a matter where the device is soft-bricked and just won't boot.
Try going here:
https://updato.com/firmware-archive-select-model?q=GALAXY+S7&exact=1&r=&v=&rpp=100
select and download the ROM that matches the country and carrier she's using, and try flashing it again.
Also note that flashing a stock, Samsung ROM will also replace TWRP with a stock Recovery.
I you need to reflash the official formware make sure to do a little research beforehand. For instance, is your firmware is aboot 5 and you flash a lower firmware with an aboot. 4 you will have a fail in Odin and your stock recovery will probably show something like
Error sw rev check fail: [aboot] fused 5> binary 4
[1]eMMC write fail:ABOOT
XDA for your specific phone and carrier and search a bit. You can always go from a lower aboot to a higher aboot (update) but gener speaking not down grade. Good luck
