Help My lg g4 broke help plz
My small sister was watching cartoons on the phone she dropped it and the gyroscope on it stopped working, i tried factory reseting it didn't work i downloaded some apps so it will help with the gyroscope but they dont give any results,
Help plz what do I do?
If the issue persists after a factory reset, it's more than likely hardware and unless you fancy a bit of DIY (and know what you're doing), it's probably not something you can fix yourself, sorry.
https://play.google.com/store/apps/details?id=com.bartat.android.elixir
Install that, then head to Sensors and hit the Play Button next to Gyroscope. Do the values change/green bar move?
yeah they move but the pointer returns to the position after mere moments
