Help My Library Widget Glitch?
Tek20
I am having an issue with the Play - My Library widget. Magazines do not show their cover at random. Instead I get a blank blue cover on the widget.
Sometimes a reboot fixes and sometimes doing a re-size on the widget fixes it. However, the problem always creeps back up. Anyone else have this issue?
I have no problem within the magazine or book app.
Update # 2:
The data reset solved the issue MOST of the time (95%). At random after a device restart I am stilling getting blank blue thumbnails on the widget.
A restart after the problem happens seems to fix it.
Anybody else have this issue? Seems to only happen if you have more than the default magazines in your library. Books also seem to be impacted as it uses the same widget.
:mad:
I have a similar issue- sometimes the covers are simply blank (transparent) rectangles. No clue how to fix, inconsistent over time. It does it to my music and books, too.
I have the exact same problem. Is there anyway to clear the data for the My Library widget? Other than a restart, I have not been able to find a way to fix it. Happens at random to me too always when I first power on the tablet. Definitely an annoying bug.
mhajii210
There was a play magazine update last week. Still the same issue is there. It helps if you wait a few minutes before unlocking the screen after a reboot.
Any other success fixing this?
Every time I reboot the widget becomes transparent and I lose the artwork.
Strange thing is that my cheepo Huawei G300 is perfect.
At least it's not just me. Lets hope there is an update soon.
Not to sort out why I get such an awful signal on O2
Starting to think I made a mistake buying the phone. All my other phones even an ancient Nokia can hold on a signal better than this.
Erm, the Nexus 10 isn't a phone bud.
Android 4.3 update and still the same glitch! Anyone found a permanent fix?
mhajii210
