Root My NC is very mad at me
JrzDroid
Android Expert
So i bought a NC from swappa and was running MIUI on it for awhile, then decided to switch to CM7. Was all good then I saw that there was a test build of Honey Comb thats working on the NC so i tried to install it and I got stuck on an Android_ screen, bad news. So I followed this:
Monster RootPack Manual
and got my NC to a black screen with a silver N and says "contains Reader mobile technology by Adobe Systems Incorporated.
Its now frozen at that screen. Someone guide me? PM me some instructions or something? Much appreciated!!
You are like my guardian angel. Not only have you helped with DX problems, but here we meet at the NC forum aswell!
Possibly!! Here's an issue though, WinImage won't recognize my MicroSD card so i can't create a bootable sd. ideas?
Run as administrator? O/W there's another program that'll write IMG files too. (w32 disk imager)
Also, remove and replace the sdcard?
FWIW I couldn't get win image to work either. Idk if its just been on my PC too long(expire trial version?) Or if something else is going on. I used w32 disk imager and it worked fine :)
I've had more luck with Win32 Disk Imager. If you're using a USB hub to connect your microSD card, try another USB port, preferably one that's built-in on the computer.
i used the Win32 Disk Imager and it worked well. MIUI back up and running on the NC!
Thanks everyone!
