Help My nexus 7 doesn
dukduken
About a few weeks ago my nexus 7 fell from the desk to my legs while charging causing a damage on the cable, after that I started to use other usb chargers like my blackberry one and the Nexus just started to get charged slower than before. After a couple of weeks the nexus was completly discharged, when I tried to charge it again using the blackberry charger it started to show this weird lines on the screen and until now I don
The Power circuit does not have enough voltage to operate - turn off and on properly ... You like many others here ran that single cell "battery" down below the minimum and now the circuitry is in a quasi on state where there is not enough power coming in to make it operate and not enough voltage to shut off so that it can charge.
you need to find a better usb charger... plug it in.. leave it alone for 4 hrs on the plug.
let the battery fully charge. LEAVE IT ALONE.
then try to turn it on.
hopefully the fall did not damage the usb port on the N7
