My note10+ touch screen acting weird help
GamerROMInc
Recognized Developer
So my phone just decided to first not have the area where the camera is to not work so when i try to pull notification down it wouldnt do anything so i set fullscreen apps to cover the camera it started to work normally like that, but after 5mins the whole touch function of the screen wont work properly making my phone do odd things whats happening
Try doing a factory reset.
If that doesn't work take it to your carrier
Yes and still didnt fix anything iceven factory restted and now none of the touch screen works it does respond to the spen but its acts up no matter what
well if a factory reset does not work then we can almost rule out a software issue. the only other way to rule out software is to try and flash a firmware update. if that does not work then we can fully rule out software and can most likely predict that it is a hardware issue.
to flash a firmware update you can go to sammobile and flash the update from there. just make sure that you get the correct firmware update specific for your exact model. sammobile will provide directions on how to install it using odin.
or you can try frija to downoload the correct firmware, you will then need odin to flash the firmware.
https://forum.xda-developers.com/t/tool-frija-samsung-firmware-downloader-checker.3910594/
