kiri4q
--------- beginning of crash
10-27 10:37:29.173 3991 3991 E AndroidRuntime: FATAL EXCEPTION: main
10-27 10:37:29.173 3991 3991 E AndroidRuntime: Process: com.topjohnwu.magisk, PID: 3991
10-27 10:37:29.173 3991 3991 E AndroidRuntime: DeadSystemException: The system died; earlier logs will point to the root cause
10-27 10:37:29.174 3991 3991 E CB : java.lang.RuntimeException: android.os.DeadSystemException
10-27 10:37:29.174 3991 3991 E CB : at android.view.inputmethod.InputMethodManager.startInputInner(InputMethodManager.java:2181)
10-27 10:37:29.174 3991 3991 E CB : at android.view.inputmethod.InputMethodManager$DelegateImpl.startInput(InputMethodManager.java:656)
10-27 10:37:29.174 3991 3991 E CB : at android.view.inputmethod.InputMethodManager$DelegateImpl.startInputAsyncOnWindowFocusGain(InputMethodManager.java:722)
10-27 10:37:29.174 3991 3991 E CB : at android.view.ImeFocusController.onPostWindowFocus(ImeFocusController.java:175)
10-27 10:37:29.174 3991 3991 E CB : at android.view.ViewRootImpl.handleWindowFocusChanged(ViewRootImpl.java:4398)
10-27 10:37:29.174 3991 3991 E CB : at android.view.ViewRootImpl.access$1800(ViewRootImpl.java:302)
10-27 10:37:29.174 3991 3991 E CB : at android.view.ViewRootImpl$ViewRootHandler.handleMessageImpl(ViewRootImpl.java:6508)
10-27 10:37:29.174 3991 3991 E CB : at android.view.ViewRootImpl$ViewRootHandler.handleMessage(ViewRootImpl.java:6403)
10-27 10:37:29.174 3991 3991 E CB : at android.os.Handler.dispatchMessage(Handler.java:106)
10-27 10:37:29.174 3991 3991 E CB : at android.os.Looper.loopOnce(Looper.java:226)
10-27 10:37:29.174 3991 3991 E CB : at android.os.Looper.loop(Looper.java:313)
10-27 10:37:29.174 3991 3991 E CB : at android.app.ActivityThread.main(ActivityThread.java:8663)
10-27 10:37:29.174 3991 3991 E CB : at java.lang.reflect.Method.invoke(Native Method)
10-27 10:37:29.174 3991 3991 E CB : at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:567)
10-27 10:37:29.174 3991 3991 E CB : at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1135)
10-27 10:37:29.174 3991 3991 E CB : Caused by: android.os.DeadSystemException
10-27 10:37:29.174 3991 3991 E CB : ... 15 more
10-27 10:38:16.274 12358 12358 E opjohnwu.magis: Not starting debugger since process cannot load the jdwp agent.
10-27 10:38:16.305 12358 12358 E USNET : USNET: appName: com.topjohnwu.magisk
10-27 10:38:16.308 12358 12358 D ProcessState: Binder ioctl to enable oneway spam detection failed: Invalid argument
10-27 10:38:16.310 12358 12358 D ActivityThread: setConscryptValidator
10-27 10:38:16.310 12358 12358 D ActivityThread: setConscryptValidator - put
10-27 10:38:16.401 12358 12358 D ActivityThread: handleBindApplication()++ app=com.topjohnwu.magisk
10-27 10:38:16.403 12358 12358 D CompatibilityChangeReporter: Compat change id reported: 171979766; UID 10334; state: ENABLED
10-27 10:38:16.450 12358 12358 V GraphicsEnvironment: ANGLE Developer option for 'com.topjohnwu.magisk' set to: 'default'
10-27 10:38:16.450 12358 12358 V GraphicsEnvironment: App is not on the allowlist for updatable production driver.
10-27 10:38:16.451 12358 12358 D LoadedApk: LoadedApk::makeApplication() appContext.mOpPackageName=com.topjohnwu.magisk appContext.mBasePackageName=com.topjohnwu.magisk
10-27 10:38:16.451 12358 12358 D NetworkSecurityConfig: No Network Security Config specified, using platform default
10-27 10:38:16.454 12358 12358 D NetworkSecurityConfig: No Network Security Config specified, using platform default
10-27 10:38:16.524 12358 12358 D ActivityThread: handleBindApplication() --
10-27 10:38:16.542 12358 12421 D OpenGLRenderer: RenderThread::requireGlContext()
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: QUALCOMM build : 3dad7f8ed7, I593c16c433
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Build Date : 10/01/21
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: OpenGL ES Shader Compiler Version: EV031.32.02.02
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Local Branch :
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Remote Branch : refs/tags/AU_LINUX_ANDROID_LA.UM.9.1.R1.11.00.00.604.073
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Remote Branch : NONE
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Reconstruct Branch : NOTHING
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Build Config : S P 10.0.7 AArch64
10-27 10:38:16.545 12358 12421 I AdrenoGLES-0: Driver Path : /vendor/lib64/egl/libGLESv2_adreno.so
10-27 10:38:16.550 12358 12358 D AppCompatDelegate: Checking for metadata for AppLocalesMetadataHolderService : Service not found
10-27 10:38:16.578 12358 12421 I AdrenoGLES-0: PFP: 0x016ee190, ME: 0x00000000
10-27 10:38:16.587 12358 12358 I AppCompatDelegate: The Activity's LayoutInflater already has a Factory installed so we can not install AppCompat's
10-27 10:38:16.599 12358 12358 D ConnectivityManager: StackLog: [android.net.ConnectivityManager.sendRequestForNetwork(ConnectivityManager.java:3925)] [android.net.ConnectivityManager.sendRequestForNetwork(ConnectivityManager.java:3967)] [android.net.ConnectivityManager.registerNetworkCallback(ConnectivityManager.java:4349)] [android.net.ConnectivityManager.registerNetworkCallback(ConnectivityManager.java:4319)] [com.topjohnwu.magisk.core.utils.NetworkObserver.<init>(SourceFile:44)] [a.B7.F(SourceFile:142)] [a.Tz.getValue(SourceFile:1)] [a.jD.KU(SourceFile:26)] [a.Qz.onCreate(SourceFile:27)] [a.qU.onCreate(SourceFile:76)] [android.app.Activity.performCreate(Activity.java:8290)] [android.app.Activity.performCreate(Activity.java:8270)] [android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1329)] [android.app.ActivityThread.performLaunchActivity(ActivityThread.java:4009)] [android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:4201)] [android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:103)] [android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:135)] [android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:95)] [android.app.ActivityThread$H.handleMessage(ActivityThread.java:2438)]
10-27 10:38:16.642 12358 12358 I DecorView: [INFO] isPopOver=false, config=true
10-27 10:38:16.642 12358 12358 I DecorView: updateCaptionType >> DecorView@44a410e[], isFloating=false, isApplication=true, hasWindowControllerCallback=true, hasWindowDecorCaption=false
10-27 10:38:16.642 12358 12358 D DecorView: setCaptionType = 0, this = DecorView@44a410e[]
10-27 10:38:16.648 12358 12358 I DecorView: getCurrentDensityDpi: from real metrics. densityDpi=560 msg=resources_loaded
10-27 10:38:16.653 12358 12421 D OpenGLRenderer: RenderThread::setGrContext()
10-27 10:38:16.677 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:16.694 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: setView = com.android.internal.policy.DecorView@44a410e TM=true
10-27 10:38:16.725 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: Relayout returned: old=(0,0,1440,3040) new=(0,0,1440,3040) req=(1440,3040)0 dur=12 res=0x7 s={true -5476376643815613728} ch=true fn=-1
10-27 10:38:16.728 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11420 android.view.ViewRootImpl.performTraversals:4193 android.view.ViewRootImpl.doTraversal:2919
10-27 10:38:16.731 12358 12421 D hw-ProcessState: Binder ioctl to enable oneway spam detection failed: Invalid argument
10-27 10:38:16.732 12358 12421 D OpenGLRenderer: eglCreateWindowSurface
10-27 10:38:17.452 12358 12358 D cm : onServiceConnected
10-27 10:38:19.591 12358 12414 W opjohnwu.magis: Long monitor contention with owner DefaultDispatcher-worker-1 (12405) at a.VY a.uT.J()(SourceFile:1) waiters=0 in a.VY a.uT.J() for 2.907s
10-27 10:38:19.749 12358 12425 V NativeCrypto: Registering com/google/android/gms/org/conscrypt/NativeCrypto's 302 native methods...
10-27 10:38:19.760 12358 12425 I ProviderInstaller: Installed default security provider GmsCore_OpenSSL
10-27 10:38:19.776 12358 12358 D CompatibilityChangeReporter: Compat change id reported: 171228096; UID 10334; state: ENABLED
10-27 10:38:19.815 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:19.845 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:19.867 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:19.874 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: Relayout returned: old=(0,0,1440,3040) new=(0,0,1440,3040) req=(1440,3040)0 dur=6 res=0x3 s={true -5476376643815613728} ch=false fn=1
10-27 10:38:19.898 12358 12421 I BufferQueueProducer: [ViewRootImpl@8f6f37a[MainActivity]#0(BLAST Consumer)0](id:304600000000,api:1,p:12358,c:12358) queueBuffer: queued for the first time.
10-27 10:38:19.902 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4995 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
10-27 10:38:19.902 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: [DP] rdf()
10-27 10:38:19.902 12358 12358 D ViewRootImpl@8f6f37a[MainActivity]: reportDrawFinished (fn: 1)
10-27 10:38:19.919 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
10-27 10:38:19.920 12358 12358 D InputMethodManager: startInputInner - Id : 0
10-27 10:38:19.920 12358 12358 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
10-27 10:38:19.943 12358 12358 D InputMethodManager: startInputInner - Id : 0
10-27 10:38:20.109 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:20.175 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:20.500 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:20.541 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:20.797 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:20.850 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:21.066 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:21.095 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:21.124 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:21.133 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: Relayout returned: old=(0,0,1440,3040) new=(0,0,1440,3040) req=(1440,3040)0 dur=5 res=0x1 s={true -5476376643815613728} ch=false fn=57
10-27 10:38:21.816 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:21.865 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:21.901 12358 12358 I DecorView: notifyKeepScreenOnChanged: keepScreenOn=false
10-27 10:38:21.910 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: Relayout returned: old=(0,0,1440,3040) new=(0,0,1440,3040) req=(1440,3040)0 dur=4 res=0x1 s={true -5476376643815613728} ch=false fn=82
10-27 10:38:22.850 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:22.980 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:22.994 12358 12358 D InputMethodManager: startInputInner - Id : 0
10-27 10:38:22.994 12358 12358 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
10-27 10:38:23.333 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:23.465 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:23.619 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:23.768 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:23.898 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:24.363 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:24.913 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:25.046 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:25.220 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:25.503 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
10-27 10:38:25.954 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 0
10-27 10:38:26.004 12358 12358 I ViewRootImpl@8f6f37a[MainActivity]: ViewPostIme pointer 1
