Help my phone heats up, need help pleaassssee or i will lose my money
meania
Hello friends,
I bought my Galaxy SL I9003 two days ago, i noticed that it keeps heating up both at the back and the front screen during using it doing anything even during opening the Gallary to choose a wallpaper, also during using net or any other operation such as calls, camera, music ..
i tried everything i could find concerning power and heating problems such as ...
- turned it to 2G
- Change brightness to Zero
- Closed Bluetooth
- Charged the battery for 8 hours
And it still always heats up after seconds from starting using it specially at the top of the screen ( the front camera erea ), Please advise me
- Is this normal generally in all android phones with same features
- Is it normal with this model specific
- Is it dangerous, is the phone going to be damaged
- Should i return it and buy another model,
( I only have less than two days to exchange it or i will have to lose so much money )
Thank you in advance, and please forgive my poor english .....
Go on and change it.
The heat should happen at the back cover while charging or during a long hour call.
Any above that, theres a problem.
Thank you for your reply
I have already done this late yesterday but i faced the same problem, i will go now and try to get another model as i found too many complains concerning this model having overheating problem all around several different android forums
This is an inherent problem. You can get a back cover so that your hands dont get hot while using it.
Hi guys!
Even i have faced a similar situation with my phone i.e. phone getting heated up.
Fortunately it is happening only while charging and that too on the back cover.
I usually charge my phone either at home or in the office. One difference i noted: In office the phone does not get heated up during charging + time to charge 100% is really less (about 4 hrs).
However, if i charge it at home, my battery gets heated up and it takes about 6 hrs to charge.
i somehow feel that this i because of the voltage/current rating that we use at home. I think my office has better, or rather apt, ratings to charge the phone. Result: i try to charge in office than home (whenerver possible) :)
Am i correct? or am i being to Einstein-y??
i dont think its the voltage. the charger has 100-240v tolerance. maybe its the environment temp itself? maybe its colder in your office than in your home? lol. just my 2 cents. it doesnt happen to my phone anyway.
its a normal seems with android espically with samsung family tough might reduce the life of certain parts IN LONG LONG RUN happens even during long use of Wi-Fi, 3G browsing toooo
