My Phone IS Alright But No Recovery Please HElp!!
AjaySingh
Recently i tried to flash something but it went wrong but my os was good but i dont know what happend my recovery is gone when i press power button and volume + i just vibrates and screen goes black !! PLease Guys HElp ME To get my recovery back!!!!!!!
You flashed the wrong recovery and borked it. Did you make a backup of the stock recovery.img prior to flashing. I'm sure it said to do so in whichever tutorial you were following.
If not you need to either find and flash the stock recovery.img or flash the whole firmware package.
But I can't find stock ROM for my android so that I can flash that's the problem or else can I flash similar stock ROM
So have you tried reflashing the recovery?
As for a stock ROM, by which I assume you mean a full stock firmware flash (as the ROM does not include the recovery), you'll need to tell us what device you have (ideally exact model number, possibly carrier) before anyone can try to help.
I am using Haier E619 I Think Its From Reliance I Search The Net For The Stock Rom But Its Not available.You Can Search For This Phone On Net. Please Guys!! Help I want to ask another thing that can I upgrade unofficially from 4.4.4 to 5.1
Unfortunately ROMs for Haier phones can be very difficult or often impossible to find, even in China. So only chance I think would be Haier service.
Recently i Found one recovery.img file and i flashed it now when i try to go to recovery the screen is white but the recovery options are working!!
Not familiar with your device, but flashing the wrong firmware is never a good idea.
Edit: If you can extract the recovery.img from the firmware package you could try to flash it separately. Still some risk there though.
I Downloaded the package of e621 and flashed only recovery using flashify as i am using a rooted android!!But that didn't work!!I Just Entered my software version in google and it showed A recovery , i flashed it and now the when i try to go the screen goes white but recovery options are working !!I even flashed wrong boot.img !! Now my boot also gone!!
I think Now the only thing is i should flash the whole firmware to bring my phone as earlier !!
Guys!! http://haiermobiles.com/index.php/download-software-and-drivers this site has the stock that is the software but i am not able to download !! Please Help Me Guys!!Almost it's since December I am Trying to recover but still no hopes!!
Any Help Please!!
