Root my phone is bricked help
Junior716
so my foneis now useless. i had cwm but it never finished backing up . now when i turn my phone on it takes me to cwm and i cant do anything. what can i do.
Hi have tried flashing the bootloop exit made by mr shabby? please try here is the link http://www.shabbypenguin.com/OUDstuff/cayman/CWM-Loop-DeLooper.zip . This will definitely fix the problem long as the system partition wasn't formatted. Download the zip, put it on your sdcard using a card reader since the phone doesn't work. Put the sdcard back in phone go to cwm then install zip file from sdcard then look for that cwm delooper zip and install and it will boot the phone normally please let us know if it works. And all credit goes to shabbypenguin for all his hard work.
ill stress this again, do not flash the delooper unless your phone is already bootable. if you break crap and make it so it wont boot normally then flahsing the delooper is just gunna make it so you have no cwm ;)
