Help My phone is charging on his own with out cable
does your phone have wireless charging? if not then i have no clue how this would even be possible. are you sure it is charging with no cables? how do you know? screenshot would help.
just remember the more info you can give us, the better we can help.
Yes I am sure
last night I put on charge in my career bedroom a morning I took it of charge and it started saying charging without cable
ok well it might say that, but it is not actually charging. this could be just a glitch in the phone. there is no way a phone can charge on its own without a charging source like a wall charger. have you tried to reboot the phone?
Unless you've discovered electricity from thin air, or perpetual motion, or little green men, it could just be a glitch or something, and it isn't actually recharging. Have you tried restarting the phone?
Yes I press volume button and off button together for 12 second
well if it is the same galaxy ace that came out in 2011, then this phone is pretty old.
it could be one of two things:
1. a software issue where a factory reset might work
2.a hardware issue with the charge port or it could even be the battery
so you can try a factory reset and see if that helps (make sure you backup your data) or maybe it is time to upgrade the phone.
