JerryTheHellbound
As the title says, my phone charges, but it won't connect to my internal memory, looking at the options i could see, tried putting Media device (MTP) and it wouldn't connect, tried to put it on USB storage, and it wouldn't connect unless i turned on USB STORAGE on USB mass storage. Yet i couldn't connect to my internal memory, (the one besides the SD card), and that is where all my music is and generally most of my files are. i use the SD card for apps and such as well, but mainly the internal memory card.
Main reason why im asking this, is because yesterday in the morning, there wasn't this problem. In fact, if i were to plug it in, it would show the phone name ("Platinum 6.0") and inside i would be able to access both the internal memory and the SD card in one. Then, in the evening, when i needed to put something in because i forgot to put it in, in the first place, this situation happened.
Oh by the way, before, yesterday morning, i could access the phone without it disabling the SD card like when you connect to it, like I connect to it now thanks to this situation.
Also, i did try different ports.
If i could get some help on this, that'd be gladly appreciated.
)...but I'm 99.999% sure it's because of USB driver conflicts (I've got a lot of Android devices and have installed tons of USB drivers (adb & fastboot) over the years--never cleaned 'em up).
