Sometimes when I plug it in it won't start charging I have to unplug and try again. Sometimes when I woke up in the morning and it was plugged in all night it will say charged and the battery indicator is full. As soon as I unplug it a pop up comes and tells me to charge and my battery indicator goes down to red zone.
Also it will not mount at all.
I called VM and they sent me a new battery. I asked if this wld fix the mount issue (pretty much already knew the answer to that tho, NO). But they said yes it wld, doubt it but gave it a try. Still not mounting. And the battery still has issues starting to charge but hasn't went from fully charged when I wake up to dead right after unplugging since new bat.
any suggestions?
BTW I already did factory reset and still same issues.
any suggestions?
