Root My plan: Please critique and give advice!
shyFluttershy
Hello, all.
My resolve to root my phone is growing stronger. I've installed Samsung Kies and have used it to back up what it can. I've also used other methods to back up my data. In theory, I'm ready to start.
First, though, I need to flesh out a plan that I can follow. Step one: do this. Step two: do that. I'd like advice and opinions on my plan.
Before I root, I intend to use the phone's factory data reset to take me back to out-of-the-box freshness. My contacts, phone logs, and texts are backed up, as well as any game data I care about, and my apps are all sitting pretty in the Google Play and Amazon Appstore cloud.
So here's my first question, a multi-parter: Should I make a backup of this pristine state? Is that necessary, or will doing a factory reset (either via the phone's in-built reset switch or via Kies) take me back to right-out-of-the-box, unrooted ICS 4.0.4 sparkly freshness? If I should back up the stock unrooted state, how do I do that? Or is that even a thing I can do? I read about using Kies to restore to out-of-the-box unrooted, but what if it upgrades me to Jelly Bean? I have no idea if or when Virgin Mobile will ever offer me the upgrade, so down the road when it's time to trade the phone in for the next new, shiny toy, I'd like to be able to put it back to the way it was when I bought it.
I suppose next on the agenda should be to download and install the magic apps that will allow me to root my phone. If you skipped the previous paragraph by deciding the answer to the first question was "no," would immediately post-root be the time to back up my phone's state? Is this what makes me able to do that?
I do not intend to install any custom ROMs or do any fancy flashing. My motivation for rooting is a modest one: I just want to be able to install/move some apps to my external SD card, maybe do some cosmetic customization. On a scale from 1 to 10, with 1 being "smooth sailing," 5 being "caution: advance with care," and 10 being "guaranteed brick," how safe would you say it would be for me to just go back to doing everything I was doing before I rooted it? The only thing I've caught wind of in these forums is "Do not install Beats Audio."
Thank you!
For one, yes backup up your current ROM through CWM.
This will make it so that you can return to it if needed.
No, factory reseting doesn't unroot, but it does wipe everything to the way it was when you bought it, with Tue exception of the root and clockworkmod recovery.
Yes you can return to stock if you find a stock ROM for the reverb.
Then you will still be able to back it up if you have CWM.
But if your current root is working fine, then there is no reason to go back to stock.
BTW, I know this is off topic but, I like your profile picture.
Im more of a Rainbow Dash person.:D
So how do you unroot, then?
Thanks. :)
Hm. Okay. My step-by-step plan so far:
  1. Back up useful data.
  2. Factory reset. ('cause I like things minty fresh)
  3. Re-activate my phone. (because data is nice)
  4. Maybe install some small essentials, or just restore my contacts list.
  5. Root using mystichunter's tutorial.
  6. Re-activate my phone. (because apparently I may need to)
  7. Side-load CWM Touch Recovery and install it.
  8. Install "Online Nandroid Backup * ROOT" -- but first install BusyBox.
  9. ???
  10. Back up my semi-pristine state, hoping that once the programs are installed, the method will be readily understandable.
  11. Finally be able to install/move apps to my SD card because my phone storage is rather small.
  12. Yay?
So, we're sure that one poot fits all, and I don't have to worry that I'm getting a file for my SGR from the Optimus Elite forums?
