Help My power control widget isn't working properly after update
gale65
My phone updated to 4.3 last week (hate the forced updates) and the power control widget doesn't work right anymore. If I delete it and then add it again, it will work for a little while. But later on it stops working. When I click something on or off, the little blue indicator doesn't come on so there's no way to know if it's on or off. I tried a different widget from the play store but it only provides shortcuts to the settings menu-it doesn't toggle things on and off by itself. Any ideas?
Try Power Toggles in the Play Store. It can use toggles for Bluetooth, GPS, etc instead of sending you to Settings
hmmmmm they appear to have changed it via an update. Sorry. It used to toggle GPS.
At least, bluetooth, mobile data, wifi, etc. still do toggle.
I guess I don't actually touch the GPS button anymore since I set up AutomateIt to do it all for me.
