Hi all,
I am totally new on android application and I have a problem. I try to build my first application on which I will type a message and it will appears on my screen but a message shows up that tells me "Unfortunately, my first app has stopped"
This is my DisplayMessageActivity.java
and this is the MainActivity.java
Code:
package com.example.firstproject;
import android.os.Bundle;
import android.app.Activity;
import android.view.MenuItem;
import android.support.v4.app.NavUtils;
import android.annotation.TargetApi;
import android.os.Build;
import android.content.Intent;
import android.widget.TextView;
public class DisplayMessageActivity extends Activity {
@Override
// Where you should perform initial setup for the activity components.
setContentView(R.layout.activity_display_message);
setupActionBar();
Intent intent = getIntent();
String message = intent.getStringExtra(MainActivity.EXTRA_MESSAGE);
TextView textView = new TextView(this);
textView.setTextSize(40);
textView.setText(message);
// Set the text view as the activity layout
setContentView(textView);
@TargetApi(Build.VERSION_CODES.HONEYCOMB)
private void setupActionBar() {
// Make sure we're running on Honeycomb or higher to use ActionBar APIs
if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.HONEYCOMB) {
// Show the Up button in the action bar.
getActionBar().setDisplayHomeAsUpEnabled(true);
@Override
public boolean onOptionsItemSelected(MenuItem item) {
switch (item.getItemId()) {
case android.R.id.home:
NavUtils.navigateUpFromSameTask(this);
return true;
return super.onOptionsItemSelected(item);
Code:
import android.view.Menu;
import android.view.View;
import android.widget.EditText;
public class MainActivity extends Activity {
public final static String EXTRA_MESSAGE = "com.example.firstproject.MESSAGE";
/** In order for the next activity to query the extra data */
@Override
setContentView(R.layout.activity_main);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
/** Called when the user clicks the Send button */
public void sendMessage(View view) {
// Do something in response to button
Intent intent = new Intent(this, DisplayMessageActivity.class);
EditText editText = (EditText) findViewById(R.id.edit_message);
/**findViewById() to get the EditText element and add its text value to the intent*/
String message = editText.getText().toString();
intent.putExtra(EXTRA_MESSAGE, message);
startActivity(intent);
