Help My S5e has been restarted randomly in every 2-10 hours, what to do to fix it?
I got Tab S5e a month ago, I've ordered it from Amazon. It was a 128 GB/6 GB version. Okay, since the day I picked it up, it works great and functions very well but it restarts randomly like a few times a day. When my tablet is off and I'm not using it at the time, it restarts randomly as Tab S5e logo appeared on screen, meaning that it resets themselves.
The tablet also turns itself on while my tablet is off and on plug charging.
The battery is still good. Both volume and power buttons aren't sticky. The tablet also rubs faster and I had no problem with that.
Here are the things I tried to prevent this but didn't help.
- Switching to Safe Mode
- Wiping system cache
- Removing the plastic rubber case
Will you help me find the solution without even returning it?
Thank you.
factory reset it. if that does not work, you have a lemon for a tablet. i would see if you still can get it returned. otherwise you will have to just deal with it.
It's only a month old so still covered under a warranty. Why are you resistant to returning it?
You can continue trying to diagnose and fix the problem, and you might be successful, but if not, why not just exchange it for one that will just work the way it's supposed to?
I forgot to mention that when either my tablet is left off while playing music or background music from a video, live or not, it doesn't restart itself, it just stays 24/7 when the video or music is played 24/7 whenever I'm playing on it or not.
It doesn't also restart itself when I was surfing the web or play games.
OK I think you solved the problem
But the problem is that, if I am tending to leave my tablet on standby while I haven't play any music or background live or not and I'm not on it. It would just restart itself for like every 2-3 hours.
While the tablet is off while it's charging, it would later turn itself on. It also restarts itself while fully charged and still plugged.
^^^^^^this^^^^^^^^
Thank you.
Try doing sysdump through adb. you'll need to enable developer mode and enable USB. Be careful, if connected to a compromised computer it could affect your device. Sysdump should have the reason it's restarting. Another option is going a bug report. Both are going to be tedious, lots of reading.
