my tablat keeps crashing
  • Start date Start date
A
Android Question
Guest
since yesterday every program keeps crashing i cant even shut it down because of the crash reports so i rebooted it and forceclosed but nothing helps.im really worried now its a new model which i bought two months ago.please help
Hello and welcome to Android Forums. Hopefully I can help you with your problem.
Try doing a factory reset. You can find the info by doing a search with your device make and model along with how to factory reset. NOTE! You will lose all data. You can also contact the manufacturer and they can walk you through the process. That should solve your problem. If it doesn't and the device is only 2 months old, either take it back to where you bought it or contact the manufacturer and send it in for repairs.
If you have any other questions regarding your device, I invite you to join Android Forums. We have many sections for specific devices which contain a wealth of information.
