I have two simple questions..at least it would probably be easier for you than I. I have no quams saying I am a newbie
1. someone recommended with touch screen phones, android, iphone even, to get a spare battery and spare battery charger.
Do you know if there is one available and if so, where?
2. the main filetype for video, I believe, is .mp4 for the Vibrant. In fact, that took a lot of file types, correct
Well, most other Androids are more limited, correct? Does the my Touch 4g take .mp4? I was told not? If so, great. If not, which file type should I use, and can I use the recommended app I have used before, anyvideoconvertor?
Thanks,
Eric
Thanks,
Eric
