drewbdope
Ok so this is the way i have my CLIQ set up and some things that I have and to me, this is the ultimate set up (with very simple tweaking).
For starters, we aren't able to root yet (maybe in a month or so?) so I need my phone to run as light and fast as possible.
The MotoBlur is a great feature to attract people, but the service isn't full Twitter, FaceBook, or Myspace. I personally think you'll get a much better experience from getting these applications separately.
I have MotoBlur still signed in (just so it can sync my contacts, settings, etc.) however, I did sign out of my facebook and twitter accounts (I dont ever use mysapce) and that meant no need for those stock widgets (the status, happenings, messages). You know what that means? Not so much data interaction even when I'm not using my phone aka longer lasting battery!
So I put the widgets in the trash and made my homescreen how I want it. My phone moves faster and lasts longer, as well as shows the freed up memory with those cancellations (about 8 to 10 MB).
Now, in my opinion, the facebook apps arent needed. The web browser on this thing brings out the website beautifully, especially in the touch interface of facebook.
Twitter does too, but it wont move as fast. So I would suggest going into the marketplace for your twitter apps. Also, I will list below the applications I have as well as why, and the amount of space they take up. Remember, the more memory used, the slower your phone performs.
Ready? Here we go...
1. "AppManager": simply manages your 3rd party applications. It enables you to install from the SD, or uninstall with ease. Also, it allows you to move and uninstalled app to the SD card, just in case you may want to re-install later on. This keeps you from having to search through the marketplace again.
Memory used = 99kb
2. "Nice Battery": One of many great battery managers out in the market. I like this for its simple battery status as well as 3G/2G shortcuts (some people don't realize you can turn 3G off to save on battery). I didn't know how to turn it off and use 2G (EDGE) until I got this app. Also, one touch bluetooth, wifi, GPS, and cell location switches are used. The application says it will notify you if you overcharge or leave services on (both optional).
Memory used = 24kb
3. "Swift Twitter": Great, light, twitter app. All the capabilities of the apps you want. If you use twitter then you know what I mean, you know what you need, and this does it. Done.
Memory used = 460 kb
4. "Rings Extended": this application allows you to use custom ringtones with much ease. If you, like myself, have downloaded ringtones from a website directly to your phone then you notice you can use them as ringtones. However, if you turn your phone off then back on, that ringtone is gone out of the phone memory. This application allows it to save the tones and directly pick them from anywhere on the SD card. Great stuff. One of my favorite apps.
Memory used = 75kb
5. "OI File Manager": OI manages your files on your SD and in the phone with simplicity and ease. There are also some great apps that do the same job, but to me, some of them have really unnecessary functions and can become confusing after a few clicks. Need to move, copy, delete? There's an app for that (suck it iPhone!)
Memory used = 149 kb
6. "TasKiller": this is the app I speak about most. This is my tiny terminator. It kills any application running in the background that you may be unaware of. You can go into the application and choose which functions to kill (and by "kill" I mean stop it from running, not eliminate it from your phone, as I think many people misinterpret). My favorite feature of this lies in the one touch killswitch widget. I have it on the 5th screen so I dont touch it by accident. It knocks everything out and you can just hit the home button and start off running only the necessary apps. Significant speed difference people! Like I said you can kill one or all functions, it's up to you.
Memory used = 171 kb
7. "SMS Backup": I haven't noticed a way to save SMS on this phone which is fine. SMS Backup does something very simple and unique. It backs all of your SMS to your Gmail folks. It creates a folder, SMS (rename it if you'd like) and stores them all conveniently in your google mail account where you can go in and view, delete, lick the screen at, etc.) Pretty sweet if you ask me. Once again, keeping internal memory free. Yes!
Memory used = 661 kb
Those are some of the great functioning apps I have running. And my phone moves very fast! I have no lag. Occasionally the accelorometer may take a half second longer, but that's about it.
Hopefully this helps. If you have any questions feel free to ask away. Peace freaks!
Memory used = 99kb
Memory used = 24kb
Memory used = 75kb
