my x8 problems
fauzan027
hello guys, sorry i'm new here
i just need ur help,
now, i can't browse my files on my x8's sd card, can u help me to fix it?
and, my messenger (sms) application always get 'hang' when i open a message or exit from a message
please help me to get this phone into primary condition again, thanks before :D
did u install anything before this happened?
can you view your images or videos?
did your messenging app force close?
umm factory reset?
if you wish to browse the files on your card you will need to install an application from the market such as Astro File Manager.
In regards to the issue with the messaging application, try this (please be aware this will also clear the massages from this application):
Main Menu > Settings > Applications > Menu Button > Filter > All > Messaging > Clear Data.
i didn't install any strange software, i just can't browse my files though my pc
but it still viewable through my x8
I see, I may have misunderstood what you are trying to do. When you connect the phone to the PC are you mounting the memory card and if so what mode do you have it in?
yes, i click on 'mount' button, but it still can't be opened
even if i click "connect your phone" , its just the same
the icons that appear just the shortcuts, not the folders/files
Just double check that it is not in MTP mode:
Main Menu > Settings > Sony Ericsson > Connectivity Settings > USB Connection Mode > make sure this is set to Mass Storage Mode.
