Okay... So I just bought MyBackup Pro and I'm finding out that the $5.00 they charge isn't covering the space on their server... The first 100 Mb is free and then it costs after that. Apparently I have much more than 100 Mb.
That would have been nice to know.
Anyway... Backing up to the SD card seems useless if you lose your phone.
Also... would it work to save the info to your SD card and then send that file to something like dropbox that gives you more free storage? Then, if you need to, you can pull it back onto your new phone and have everything back. Seems like a lot of hassle for something so basic and essential. (maybe not basic, but widely desired I would think)
Is there a better way?
Doesn't the iPhone do this stuff for free in their cloud without you having to think about it?
The obvious goal here is to turn on a brand new phone and be able to pull everything up like it was on your old phone... appearance, widgets, home screen, preferences, etc.
I have a razr running ICS. not rooted.
