mym itt
  • Start date Start date
A
Android Question
Guest
GN plaI was downloading a game and it said parasing error how do I fix that so I can play my game
If you were downloading it from the Play store, try downloading it again. If it still happens, notify Google - there's a problem with the file you're downloading.
If you're downloading it from somewhere else, it probably means that the game won't install on your hardware, your version of Android or both. (The Play store maintains multiple versions of each app and sends your device the proper one for that device.)
