myRemote: great remote
  • Thread starter Thread starter technique
  • Start date Start date
T
technique
Guest
i use this all the time so i can listen to music out side well my laptop is hooked up inside to house speakers. The only issue/complaint is the volume control.
For anyone that is interested, you can use MyRemote over your 3G network.
All you have to do is forward ports 9875 to 9878 on your router to your PC running the myRemote software.
Then use your router's IP address (from your internet provider) in your myRemote software on your droid.
It is surprisingly responsive and there is no need to drain your battery running WIFI.
Hi, thanks for this info, however it doesn't work for me. I am familiar with forwarding ports and other ports I forward do work. Are these ports you listed supposed to be tcp, udp, or both?
Thanks!
