Help Mysterious LED notification
Hi guys
I have a very annoying problem with my LG G3.
Sometimes after receiving a WhatsApp msg or sms, the green LED notification doesn't go away after I have read the message. There is nothing on the notification panel, or anywhere else. But the LED keeps blinking green. This eventually goes away after I have received another message.
Any ideas?
Sounds like a bug: something isn't cancelling the LED notification. If that affects both WhatsApp and standard SMS it sounds like an LG bug rather than an app bug. I don't know whether there is a workaround, but I'd be tempted to try informing LG of it.
I'm not familiar with whatsapp but does it require you to set it as the default messaging app so that you don't receive multiple notifications?
The problem I have is that I am not really sure which app is causing the problem. It usually happens when I get an sms while I am in WhatsApp checking messages. Going to try installing a LED notification manager. Will let you guys now if it works.
