rinnycoop121
Android Assistant & Bloat Freeze (any others you recomend would be fine)
Ok what should and should not disable using Android Assistant & Bloat Freeze (or do you recommend a better app?)
I have been trying to get my phone running on top performance and save battery as well.
I am rooted and have SetCPU app set to max and have different profiles set.
SO what should i disable and not disable with the Mytouch 4G?
Let me know please.
thank you.
Let me know please.
thank you.
